Aux Shaft bolt torque spec?
- Topless
- Your car is a: 1979 Fiat 124 Spider 2000
It's strangely missing from all online conversations, and I haven't yet found it in the service manual... anyone know what it is? I checked torque specs in the manual but didn't see it listed, and also the Aux Gear section but also not there.
Re: Aux Shaft bolt torque spec?
I've always assumed 87 ft lbs, just like the cam pulleys. Same bolts, same shaft steel, same pulleys, same operational speed.
