hose size (tank to pump)? 82 F.I. spider
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
Hey Guys, does anyone know what size the hose is between the f/tank & pump on a f.i. Spider? The external size looks much larger than the high pressure side, but I don't know if it's larger i.d. or just thicker hose. I don't really want to pull it off until I get the correct hose, (I got enough of a gas bath changing the filter & High pres hose).thanks
Trey
pope
Re: hose size (tank to pump)? 82 F.I. spider
Post by pope »
Sometimes if you hold your cigarette close to the hose, you can read the size of the hose on the side of it. Of course that might be the last thing you read! :shock:
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
I once saw a guy attempting to install a dist in a small block Chevy use a lighter to look in to align the oil pump shaft. Just as someone said "I wouldn't do that", the crank case vapors ignited & singed off most his hair!
Trey
kristoj
Your car is a: 1982 Fiat Spider 2000 Turbo
Post by kristoj »
I'm not sure what size it is, but it is definitely a larger I.D., not a thicker hose. I bought a new fuel pump that I intend to install this weekend, and the inlet is visibly larger than the outlet (I believe the high pressure side is 8mm I.D.) I would go out and measure it for you, but I am currently out of town. My guess would be 9 or 10mm I.D.
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'62 Lancia Flaminia 2.5 3C Convertible
'68 Lancia Fulvia Sport Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
it's roughly 1/2 diameter
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
thanks!
Trey
kristoj
Post by kristoj »
I just installed my fuel pump today. The inside diameter of the inlet hose in 12mm. I ended up using 7/16 I.D. fuel hose (11.1mm) as the 1/2 inch (12.8mm) seemed too loose.
John
'12 Abarth 500
htchevyii
Patron 2022
Patron 2022
Post by htchevyii »
you're right, 7/16 was perfect. thanks
Trey
