Pedal Assembly
Fiat124Spider75
Your car is a: 1975spider
Pedal Assembly
Post by Fiat124Spider75 »
Hi all,
Has anyone removed the clutch and brake pedal assembly? I have a ‘75 spider. I tried pulling the main bolt out and fell into some trouble. Anyone with experience in this care to share a tip or trick?
Re: Pedal Assembly
What trouble did you fall into? Note that it's far easier to install the brake and clutch pedals without the various springs and linkages attached to them. Once the main bolt (shaft) is installed, then you can reconnect the clutch cable, clutch pedal assist spring, brake linkage rod and clip, brake return spring, etc.
