Hoisting engine out
grasshopper
Your car is a: 1976 Fiat Spider
Hoisting engine out
Post by grasshopper »
Hi everyone. I need to hoist my engine out of my 76 Spider. Is it better to leave engine mounts on crossmember and just un bolt engine from top of mount and lift engine off of mounts or is it better to unbolt mount from underneath cross member and just lift out engine with mounts still attached to engine ? I am hoping for a snag free lift. Thanks.
Re: Hoisting engine out
Ahhh, Grasshopper. Remove the top nut and leave the rubber engine mount in the car when you pull the engine. When you reinstall, loosen the lower nut on the mount so you can move it around as you lower the engine back down on the mount.
“Nothing more, my son. But if you choose to think there may be more, you are welcome to follow.”
grasshopper
Thanks Bryan. That is helpful and you made me laugh. lol
