timing pointer without a frt cover
htchevyii
Post by htchevyii »
Hey guys, I want to leave the ugly yellow t/belt cover off of my '72 1608, but the timing marks are on the cover. What are you using for timing marks? I thought of using one like my 2000 and remarking the pulley, anyone have a better way? thanks
Trey
rlux4
Re: timing pointer without a frt cover
Post by rlux4 »
Trey, does the 1608 have the holes on the block to mount an idicator plate over the pulley like our cars have?
Ron
Ron Luxmore
rlux2n2@gmail.com
mbouse
Post by mbouse »
paint the ugly yellow some other color !!
rlux4
Post by rlux4 »
Another color. Yeah...that's a good idea. Got any suggestions Mike?
Ron
Ron Luxmore
rlux2n2@gmail.com
Tappy
Your car is a: 124 spider 2000 1979
Post by Tappy »
before i hear somone suggest "cracle" i want to recomment hammerite
it looks like this Image
and is available in many colors
and you can use it on some other metal pieces from your car it prevents rust
Back to you mike ....
FineItalianAutomobile TechnologyImage
mbouse
Post by mbouse »
well... let me think about it for a second or two...
was there any question what my suggestion might be?
rlux4
Post by rlux4 »
Hey! You did the timing cover too.
(I didn't know how to say it without using the "C" word.)
Ron
Ron Luxmore
rlux2n2@gmail.com
mbouse
Post by mbouse »
and the throttle springs match the cooling fan without CRACKLE
wmpwilson
Post by wmpwilson »
The question wasn't really answered, and since I bought my 1977 Fiat 1800 without a timing cover, I am interested in what I can do to get accurate timing. Do I need to buy a cover from someplace? If so, does anyone know of a source?
I've got loads of used covers, but it wouldn't be hard to fabricate a pointer and bolt it on the front of the engine
rlux4
Post by rlux4 »
Mark, that's the reason I asked it there was the place on the front of the block to bolt on a pointer. If the two holes are there for the pointer used on the later engines it already has the "0", "5", and "10" degree marks on it. Seems to me that the pointer is a lot easier to use than the front of the cover. If the V-notch isn't on the pulley it would be easy enough to mark TDC on it.
Ron
Ron Luxmore
rlux2n2@gmail.com
