wiring confusion
geospider
wiring confusion
Post by geospider »
putting the center console back in.
these wire connectors were/are just hanging. never unplugged them. just had 3 small single connectors to the heat/def switch, etc.
thinking of just stuffing them back in there. just strange. no, not sure I have a diagram and they confuse me anyway.
help
Geo
Re: wiring confusion
This is common Many Fiat Spiders left factory pre wired for a radio and power antenna. In addition others also had wire/connectors for electric window switches. All of these connectors were stored behind the upper center console
geospider
Post by geospider »
Well that makes some sense. now I just need to find the "radio" hot wire from the ignition. PO had the raido powered through the Cig lighter.
thanks
The radio connector had 8 cavities the brown wire is Hot in "start and run" The white/black wire is ground the left speaker wires are gray/black and violet/black the right speaker wires are gray and violet 2 of the connector cavities have no wires.
geospider
Post by geospider »
Thanks. First think I do when getting home from work.
