Replacement Dashboard
I'm looking to get a new dashboard for my 1978 2000 - something different from the normal tan wood - does anyone have any recommendations?
Re: Replacement Dashboard
are you asking about just the wood or a replacement dashboard? I have the wood in several different stains now
Hi Mark - I'm looking for just the wood - something a bit interesting. Can you post a link to what you have in stock?
- michaelj
- Your car is a: 1976 Spyder
Check the parts section. There is a guy on there selling Phillipine Mahogany and it looks great. Reasonable too.
- spidernut
You can also veneer over the existing wood. This company even has a peel and stick version of the veneers.
http://www.veneersupplies.com/categorie ... __A__-__L/
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
I had a custom set of carbon fiber (not vinyl imitation) dash and center console made. I think they look pretty good.
Later I changed the center of the dash and installed 2 cup holders
- MrJD
Dang mark... that walnut is hot...
- spidernut
Here's what happens when you put about 10 coats of high gloss urethane on a walnut dash.
John G.
- bradartigue
That looks fantastic. What model year did the wood come from? I'm asking because some were solid wood and some had a veneer.spidernut wrote:Here's what happens when you put about 10 coats of high gloss urethane on a walnut dash.
1970 124 Spider
http://www.artigue.com/fiat
pretty nice indeed.spidernut wrote:Here's what happens when you put about 10 coats of high gloss urethane on a walnut dash.
looks like the back of the finest guitars... with a stronger sound, I guess.
- spidernut
It was purchased by the prior owner and never installed. It was solid walnut with a thin coat of lacquer. I sanded it down, then applied repeated coats (sanding in between) and then final sanding it with 2000 grit wet or dry paper then buffing it out.
John G.
- MrJD
That looks fantastic... I might copy you.
- Your car is a: 1967 Fiat 124 Spider
