Wind Deflector
Re: Wind Deflector
Yes, I will agree on the better packaging needed; my box was all banged up from the multiple handling but the inside was ok. They should have put the box in another box so I will let them know of this problem. The screen material is a little more fragile than the IAP one but should be ok if I am careful; the frame and stitched vinyl covering are exactly as the IAP one.
Warren
Sylacauga Alabama
1979 Fiat Spider Automatic
1991 Alfa Romeo Spider Veloce
1974 Dodge Dart Sport Hang 10 (in restoration)
Multiple other cars, trucks, and boats
Sylacauga Alabama
- Razooli
- Your car is a: 1982 Fiat Spider 2000
Re: Wind Deflector
Warren,Warren wrote: I found that Raceland (website http://www.Racelandus.com) has a Windblokker for a Mazda Miata. They emailed me the dimensions and after verifying this will work for a Fiat Spider, I ordered one.
Did you order the normal "rectangular" one or one of the spiffy "V" or "R" shapes? Also, could you share the dimensions Racelandus gave you?
Thanks!
Lynn Shuler
1982 Spider 2000
Remember, this hobby is supposed to be your therapy, not the reason you need therapy.
1982 Spider 2000
Re: Wind Deflector
Lynn, I ordered the rectangular one. The dimensions are 13.5" high and 39.25" long on the bottom from threaded stud end to threaded stud end. Preliminary fitting indicates installing closer to the headrests will allow tilting down (when desired) to avoid hitting the rear window.
Warren
Sylacauga Alabama
Sylacauga Alabama
Re: Wind Deflector
I got mine from Brady Jones, not sure if he is still making them. http://www.fiatspider.com/f08/memberlis ... ile&u=5827.
Quality is very good and it really works.
Re: Wind Deflector
That looks like it sits up too high...especially in the second photo.
Re: Wind Deflector
In photos it looks high but in reality it looks perfect. It does an amazing job of cutting down the wind turbulence. Since Jersey is all highways its perfect for around here. For local driving I take it off .
Re: Wind Deflector
I've got Brady's roll bar mounted one. It blends into the roll bar very well and is a much more durable mesh than the Raceland ones.
http://www.fiatspider.com/f08/viewtopic ... ind#p95708
Trey
Re: Wind Deflector
Hi all,
Just wanted to let you know I'm still making the wind screens.
Just pm or email me if interested.
Re: Wind Deflector
I completed my installation of my Windblokker and it works perfectly; makes a big difference on the highway as the one on my Alfa. I have not figured out how to load up some pictures so if anyone interested please email me at whhopson@southernco.com. Also I have some bracket details; brackets bent on a vise. Brackets made with similar dimensions will allow the screen to fold back without hitting the rear window with the top up. You will also need to install some short strips of plastic molding on the contact areas on the side rear vinyl cover and the top frame; the molding is available from auto body/marine supply shops and J. C. Whitney. I will be sending details to Raceland so they may start making their own brackets.
Warren
Sylacauga Alabama
Sylacauga Alabama
Re: Wind Deflector
I have Brady's screen installed...we all love it
Top clears just fine (note seat belt guides as well)
Re: Wind Deflector
brady from NJ makes and sells them. Sorry i cant copy and post. On my cell phone. But he did just list a bunch or random parts for sale. Some wheel spacers, vent window sills , and a couple other odds and ends. He also sells stainless heat shields for you exhaust mainifold and a stainless piece for air filter if a aftermarket air filter like K
Re: Wind Deflector
I have revised my Windblokker installation to include the 2" brackets suppled with the Racelandus.com Miata screen. This allows custom adjustment to be closer to the headrest and higher to eliminate the minor rear visibility blockage which previously existed. Also since your frame mounting bolts may not be at the same height, as mine were not, this will allow some adjustment to have the screen level (with the windshield as a reference). Email me at whhopson@southernco.com for some pictures of this revised installation.
Warren
Sylacauga Alabama
Sylacauga Alabama
- Razooli
Re: Wind Deflector
I just finished installing one of Raceland's windscreens - a Windblocker V Style for Miata. For $39, you can't beat it. (Thanks, Warren!) I had a prototype of a headrest-retained one a friend made years ago and it was too short to be really effective plus I got tired of having to have the seats reclined at the same angle and having to remove the headrests every time I wanted it off. I liked Warren's installation method, but I live in SoCal, and the top is hardly ever up - I'd have to cut a slit in my boot to accommodate the bracket if I wanted it on at the same time as the windscreen.
I had already removed the rear seat back and put my rear speakers in boxes sitting on the rear seat, so I decided to follow Foster48x's plans for a rear deck replacing the seat and a single speaker box to fit both of my 6X9s. I was in a yacht surplus store when I saw a used 6' chrome handrail for $10. It had studs at the ends and looked perfect to mount the Windblocker brackets. I cut it in half, drilled holes in the deck, added some used marine hardware to hold the poles straight, attached the windscreen and here's the result.
Windblocker1 on Flickr
It flips up and down with ease, no cuts to boot, speakers sound great, the pole-and-screen assembly can be pulled out and stowed in the trunk and most important
... my wife's hair no longer blows into her face.
Click on the above Flickr link for more construction photos in the Windblocker set.
Many thanks to Foster48x for his great set of plans and again to Warren for his tips and finding this bargain.
Lynn Shuler
1982 Spider 2000
1982 Spider 2000
- dantye
- Your car is a: all gone
Re: Wind Deflector
FYI: Headrest mounted wind deflectors can be two separate units.
Bruce Hendricks' version, photographed at ChiFLUs FUN11 event. Made from PVC pipe, screen and foam pipe insulation.
- courtenay
Re: Wind Deflector
Sorry, Dantye - gotta say I like Brady's version better. Less bulky.
Bruce Shearer
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
'80 Spider Fi
'10 Volvo XC70
'06 GMC 1 Ton PU
