cloudy to clear
Re: cloudy to clear
we've just been replacing the entire clock with a VDO unit. They match the original look and work flawlessly
- spidernut
Re: cloudy to clear
I cut my own lens out of a CD jewel case. It works perfectly.
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
Re: cloudy to clear
What does that cost markSo Cal Mark wrote:we've just been replacing the entire clock with a VDO unit. They match the original look and work flawlessly
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
Re: cloudy to clear
well i got the right size lens on Saturday, got my clock put together, looks great. the lens is slight thinner then the original,, bezel cover snaps back in place
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- SLOSpider
- Your car is a: 1973 124 Spider 2.0FI
Re: cloudy to clear
Awesome. Going to give that a try right now!spidernut wrote:I cut my own lens out of a CD jewel case. It works perfectly.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Re: cloudy to clear
how did you get the bezel off cleanly. My PO gave me a few extra instruments including a spare clock and I distorted both the bezels terribly trying to get them off as practice.
Id like to replace them with chrome ones and dont like the "heavy" look of the chrome ones that fit over the originals...
Re: cloudy to clear
maybe a used clock from a first generation spider would be fine?georgeramos wrote:how did you get the bezel off cleanly. My PO gave me a few extra instruments including a spare clock and I distorted both the bezels terribly trying to get them off as practice.
that's what I have and it looks great !
Re: cloudy to clear
That's a cool steering wheel westy64. Did you paint the dash black or did you cover it with vinyl ?
- SLOSpider
Re: cloudy to clear
I used one of the old time can openers, You know the one for poking holes and the other side to remove bottle caps. The Cap end I ground down so it was flat the sharpened the edges of it so it could get in the bezel rings. As others have stated I think this must be a heavier metal as it is a pain to get up. As long has you can get enough of the metal up and not broken then it will go make on. They also have the replacement chrome/ss ones but big dollars.georgeramos wrote:how did you get the bezel off cleanly. My PO gave me a few extra instruments including a spare clock and I distorted both the bezels terribly trying to get them off as practice.
- spidernut
Re: cloudy to clear
The lip of the bezel does not need to be bent up vertically for the bezel to be removed - it can be stretched horizontally (stretched into a larger circumference) and still come off. I found this to work better than trying to pry up the lip though both methods do work.
If you use this method, it can be reinstalled by putting the bezel back onto the clock and rolling the clock (like a wheel) with the bezel on a hard surface (I use a thin rag so the bezel doesn't scratch). By rolling the clock (pressing downward), it reduces the circumference by stretching it back into its original shape.
John G.
Re: cloudy to clear
What did you use to "stretch" the bezel John? Also, if Im able to get them removed is there an easy(er) way to remove the anodizing to polish the aluminum?
thanks
thanks
Re: cloudy to clear
I did not do anything, but a PO did.Tobi wrote:That's a cool steering wheel westy64. Did you paint the dash black or did you cover it with vinyl ?
The wheel is a standard model from the OMP brand (common car racing catalog).
The dash was finely sanded then lacquered in black.
I had to rework the glove box door as it was worn due to the PO's tripmaster screw holes, and it has simply been filled with body filler, then sanded and painted black.
There's no difference with the rest of the dashboard.
Re: cloudy to clear
I guess it is this one
http://www.ompracing.it/detail.html?productcode=OD/1950
here's how it was when I got the car
- spidernut
Re: cloudy to clear
A teaspoon worked quite well without damaging the bezel...keeping the outer curve of the spoon against the bezel as not to have any sharp edges come in contact with the bezel lip. The lower the quality of spoon the better - you need one that is pretty thin. I had to go around the bezel about three times before I got it stretched enough to take off. I'd recommend being very careful trying to remove the anodizing and attempting to buff them out...they are REALLY thin and bend very easily.
John G.
Re: cloudy to clear
Thats what i thought. Looks like my next AutoRicambi order will include a set of replacements.
All of this is based on IF, and only IF, I can build my own custom steering wheel. My "spare" Ebay one is on its way...
